Static DHCP not working
Yoe777
in Home Router
I setup a Static DHCP with the correct Mac ID however my Zyxel VMG4927-B50A is not assigning it to the device even though it is set to active. What is the problem?
Hello @Yoe777
Are you able to say what version of firmware you are using in your Zyxel VMG4927-B50A please?
Kind regards,
Tony0
- 603 USG FLEX H Series
- 481 News and Release
