Static DHCP not working
I setup a Static DHCP with the correct Mac ID however my Zyxel VMG4927-B50A is not assigning it to the device even though it is set to active.   What is the problem?
  • tonygibbs16
    tonygibbs16 Posts: 977  Guru Member
    Hello @Yoe777
    Are you able to say what version of firmware you are using in your Zyxel VMG4927-B50A please?
    Kind regards,
         Tony
  • mMontana
    mMontana Posts: 1,426  Guru Member
    @Yoe777 the device who should have a static IP via DHCP is a tablet/smartphone?
