Connecting 2x Multi X through NWA55AXE --> one domain
I am trying to set up two houses with about 50 yard distance working in the same network described in the picture below. I am bit confused: can I use Multy App or Nebule App to do that or should I use separate apps for each segment.
How should I configure the network?
Is there a tutor suggesting how to do that?
I am a novice with these type of networks.
Thank you!
// uc
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,342  Zyxel Employee
    edited August 2022
    Hi @uch
    The scenario would not work in this case, the Multy X on the right side of the picture could not recognize the mesh on the left side.
    You can consider substituting the NWA55AXE on the right side in the scenario into the LTE series.
  • uch
    uch Posts: 3
    thx jerry - so you mean that I cannot plug the other NWA55AXE in Multi X LAN port and the other building NWA55AXE in Multi X WAN port and create a wireless bridge, which connects these Multies into the same mesh?
  • Zyxel_Jerry
    Hi @uch
    As the topology you provided, the right side of the Multy X is not able to recognize the Multy backhaul behind the mesh of NWA55AXE.
