Change Nebula Mode Flex 200 to a 700
Hi All
Just checking that I have this right..
1. Remove Flex 200 From site
2. Add Flex700 (in Inventory already) to the old 200 site
3. Press and hold reset button and have a means of internet connectivity in P2 to allow Flex 700 to sync Nebula config.
4. When Flex 700 goes offline after a few minutes patch in correct WAN cables.
Also will all NAT and other configs on the site be preserved for the better flex700?
Hello @Pook,Yes, you could upgrade device from USG FLEX 200 to USG FLEX 700, and the steps are correct. Please note that some config such as port configure, needs to be checked again.BTW, upgrade to higher level device is ok, but downgrade to lower level is not ok. Thank you.James1
Thanks James, much appreciated :-)0
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
