Zyxel Speedlink 5501 Configuration for DGF
JoSf
in Home Router
I have changed from "Deutsche Telekom" to "Deutsche Glasfaser", Zyxel configuration changed to "behind a Router with DHCP". Internet works, but now I have to configure VOIP provider. The "Anbietername" is free to choose, I took "DeutscheGlasfaser". The next fields are Konto-Domain, SIP-Proxy, SIP-Registrar and Outgoing Proxy. I always took dg.voip.dg-w.de, but this does not work. Who can help me for the right config entries?
Hello @JoSf
The user manual at https://www.zyxel.com/de/de/uploads/images/170811_BA_VMG8546.PDF could help you, especially section called VoIP-Anbieter einrichten on page 84.
Most of the information you need has to come from the VoIP provider you have chosen, such as Sipgate Basic, see https://www.sipgate.de/blog/kategorie/sipgate-basic?gclid=CjwKCAjw3qGYBhBSEiwAcnTRLi1_z4F3peH5cLzRukwyWtlfNcPkjjJ4O0v8RBnSkUD3iIQa0M0HLRoC3EIQAvD_BwE
Tschüss and Kind regards,
Tony
Hello @JoSf
Tony
Hello Tony,
Thank you for providing me the link to the Zyxel handbook. I was able to resolve the issue, main point was to use for VOIP configuration the "Configuration assistent" instead of trying to insert the config manually.1
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
