[NEBULA] Can NSG100 see the usage of all users going to which websites?
Hi JINHANG, Welcome to Nebula Forum!
You can configure application profiles for the specific/pre-defined applications (websites), enabling the Log option which will allow you to check the IP addresses that are connecting to this site in the Gateway > Event log page.0 -
Can you provide a screenshot of NCC on what you are describing above? Thanks0
For instance, if you want to check the devices that are accessing to Youtube you can create a application profile (Gateway > Configure > Firewall) using the pre-defined options for youtube, action "Forward", "Log" option and creating the outbound rule with source "any" or specifying the network address you want to monitor:
Once you have create the profile and rule, you will be able to check the devices connecting to youtube in Gateway > Monitor> Event Log filtering by Application patrol category:
- 220 Nebula Ideas
- 602 USG FLEX H Series
- 480 News and Release
ZCNE Certified
