SSLVPN WIN 11 DISCONNECT
D2IT
When trying to connect me to the vpn via Secuextender, it automatically disconnects
Hi @D2IT
You can make sure Zyxel SecuExtender TAP-Windows Interface installed successfully first.
If issue happened again, please share SecuExtenderlog for further check this issue.C:\SecuExtenderHelper.logC:\Users\[windows account]\SecuExtender.log0 -
below my log , Interface TAP-Windows instalada com sucesso[ 2022/08/26 18:15:41 ][SecuExtender Helper] Request(102): REMOVE 587311296/496864177 21 4294967295 4294967295[ 2022/08/26 18:15:41 ][SecuExtender Helper] Remove Routing[ 2022/08/26 18:15:41 ][SecuExtender Helper] Remove prioritize routing[ 2022/08/26 18:15:41 ][SecuExtender Helper] Fail to delete prioritize route to 177.139.157.29, 255.255.255.255, error = 1168[ 2022/08/26 18:15:41 ][SecuExtender Helper] Fail to delete prioritize route to 177.139.157.29, 255.255.255.255, error = 1168[ 2022/08/26 18:15:41 ][SecuExtender Helper] Get netsh path = powershell[ 2022/08/26 18:15:41 ][SecuExtender Helper] Set-NetIPInterface -InterfaceAlias "Ethernet 2" -InterfaceMetric 30[ 2022/08/26 18:15:41 ][SecuExtender Helper] ZyShellExecute start.[ 2022/08/26 18:17:45 ][SecuExtender Helper] ######## Build Datetime: Jan 25 2021/13:07:57 ########[ 2022/08/26 18:17:45 ][SecuExtender Helper] osvi.dwPlatformId = 2, osvi.dwMajorVersion = 6, osvi.dwMinorVersion = 2[ 2022/08/26 18:17:45 ][SecuExtender Helper] shared memory is create[ 2022/08/26 18:17:45 ][SecuExtender Helper] Get a valid selfsigned certificate.[ 2022/08/26 18:17:45 ][SecuExtender Helper] certificate fingerprint: a1003e4db673c52f4624eeb5bcd47141dfc7f208[ 2022/08/26 18:17:46 ][SecuExtender Helper] https server init success[ 2022/08/26 18:21:37 ][SecuExtender Helper] Request(100): REMOVE 587311296/496864177 6 4294967295 4294967295[ 2022/08/26 18:21:37 ][SecuExtender Helper] Remove Routing[ 2022/08/26 18:21:37 ][SecuExtender Helper] Remove prioritize routing[ 2022/08/26 18:21:37 ][SecuExtender Helper] Get netsh path = powershell[ 2022/08/26 18:21:37 ][SecuExtender Helper] ia is null[ 2022/08/26 18:21:37 ][SecuExtender Helper] Failed to read from client(2): 109, 0[ 2022/08/26 18:21:37 ][SecuExtender Helper] Start to Disconnect pipe...[ 2022/08/26 18:21:37 ][SecuExtender Helper] Shutting down a pipe connection instance...[ 2022/08/26 18:21:37 ][SecuExtender Helper] ==============================0
my firewall usg flex 200 firmware is V5.31(ABUI.0)0
We are having several problems disconnecting users using sslvpn
Stanley we will perform the firmware update today, tomorrow I'll be back to tell you the answer
- 238 Nebula Ideas
- 6.8K Security
- 754 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
