SSLVPN not able to connect to LAN1
tkgn
tkgn Posts: 1 image  Freshman Member
Third Anniversary
LAN1 client (10.10.100.9)
SSL VPN client (10.10.200.11)
SSL VPN client can not ping 10.10.200.1
SSL VPN client (SecuExtender) connect successfully (including 2FA with email)
try all different suggestions,  need help please
I'm missing a security rule or routing problem ?
Where should I check the log  ?
  • Zyxel_Cooldia
    Hi @tkgn,
    Welcome to Zyxel community. =)
    Please go to "CONFIGURATION > VPN > SSL VPN >  Global Setting page, and modify Network extension Local IP to 192.168.200.1. it would have routing issue if Network extension Local IP is same subnet as VPN pool.
    PeterUK Posts: 4,392 image  Guru Member
    edited August 2022
    Their will be no DNS at 10.10.200.1 you need to use 10.10.100.1
    Also the LAN1 client (10.10.100.9) willl not use 10.10.200.11 by SSL VPN to get to 10.10.100.10 say because windows will use 10.10.100.9 to get to 10.10.100.10.
