NAS 542 dead
Pandino84
Posts: 14 Freshman Member
hi, after a failed update of firmware my nas542 seem dead.
when on it restart continuosly... no assistance for me in italy... any idea?
There is a worldwide website include country local support.You can find Italy local support here.
thanks ikubuf, but turin don't support private nas for local policy. no one of the zyxel partner soing it. this forum is the only hope or i have to trash it....0
You can try a 'RescueStick'. Here I have one for the '540, that can be adapted for the '542. Extract the zipfile to a (fat formatted) USB thumb drive, replace the ras.bin file by the <firmware>.bin from a 542, and adapt some textfile to have the right md5 sum of the new ras.bin file. Plug the thumb drive in, and boot the NAS. If you are lucky, it will reflash the firmware and cure the problem.
2 -
thanks mijzelf.
i try you'r solution with a friend tomorrow evening... 4 eyes are better than 2
i'll provide you any update.
for now thanks
if i ahve problem can you prepare to me a 'personalized' rescuestick? your instruction are pretty simple but i'm a newby....
for modify the textfile is ok wordpad?0 -
@Pandino84 I'd suggest you to use Notepad++0
thanks mMontana0
Yes, I can. But I have no way to test it, so it's only best effort.
thanks mijzelf. i wry for now with my own, in case of failure i ask you0
update.
usb key formatted fat inserted in tre front port usb
blinking red led usb
i post the flash log+ FW_FILE=/mnt/partnerkey/nas5xx_fw/ras.bin+ NANDPATH=/firmware/mnt/nand2+ /firmware/sbin/info_printenv curr_bootfrom+ awk -F= {print $2}+ CURR_BOOTFROM=1+ [ 1 -eq 1 ]+ NEXT_BOOTFROM=2+ /firmware/sbin/info_printenv kernel_mtd_1+ awk -F= {print $2}+ CURR_KERNEL_MTD=4+ /firmware/sbin/info_printenv sysimg_mtd_1+ awk -F= {print $2}+ CURR_IMG_MTD=5+ /firmware/sbin/info_printenv kernel_mtd_2+ awk -F= {print $2}+ NEXT_KERNEL_MTD=6+ /firmware/sbin/info_printenv sysimg_mtd_2+ awk -F= {print $2}+ NEXT_IMG_MTD=7+ md5sum -c /mnt/partnerkey/nas5xx_fw/ras.bin.md5sum/mnt/partnerkey/nas5xx_fw/ras.bin: OK+ [ 0 -ne 0 ]+ /sbin/setLED SYS ORANGE BLINKFail to open gpio device+ sleep 1+ mkdir -p /mnt/partnerkey/buffer+ /sbin/bin2ram little /mnt/partnerkey/nas5xx_fw/ras.bin /mnt/partnerkey/buffer/tlv.bin+ [ 4 -ne 4 ]+ sync+ sleep 1+ cd /mnt/partnerkey/buffer+ /sbin/fw_unpack -C . -i ./tlv.bin+ [ 0 -ne 0 ]+ sync+ sync+ ls /mnt/partnerkey/bufferDATA_0000DATA_0001DATA_0002DATA_0101DATA_0200DATA_0201DATA_0202DATA_0203DATA_0204DATA_1000DATA_1004DATA_a000DATA_a002tlv.bin+ sleep 10+ /bin/rm -f /mnt/partnerkey/buffer/tlv.bin+ [ -s /mnt/partnerkey/buffer/DATA_0101 ]+ /firmware/sbin/mrd_model -p+ board_model=B203+ cat /mnt/partnerkey/buffer/DATA_0101+ file_model=B103+ echo -n board_model=(B203), file_model=(B103) ...board_model=(B203), file_model=(B103) ... + [ xB203 == xB103 ]+ echo NOT equal! /firmware/sbin/mrd_model -s B103NOT equal! /firmware/sbin/mrd_model -s B103+ error_exit+ setLED SYS RED BLINKFail to open gpio device+ setLED HDD1 RED BLINKFail to open gpio device+ setLED HDD2 RED BLINKFail to open gpio device+ setLED HDD3 RED BLINKFail to open gpio device+ setLED HDD4 RED BLINKFail to open gpio device+ setLED COPY RED BLINKFail to open gpio device+ /bin/sync+ read
help thanks
i use last firware for 5420 -
board_model=(B203), file_model=(B103) ... + [ xB203 == xB103 ]NOT equal! /firmware/sbin/mrd_model -s B103According to this lines you used a firmware file of the '540 (B103). Did you exchange the ras.bin? And your board is a '520. (B203). A 542 is a B403. Are you sure you have a 542?
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 288 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 252 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
