[NEBULA] Can NSG100 see the usage of all users going to which websites?
JINHANG
JINHANG Posts: 10 image  ZCNE Certified
First Comment Second Anniversary ZCNE Security Level 1 Certification - 2019 ZCNE Nebula Level 1 Certification - 2019
edited April 2021 in Nebula
  • Nebula_Bayardo
    Nebula_Bayardo Posts: 179 image  Zyxel Employee
    Hi JINHANG, Welcome to Nebula Forum!
    You can configure application profiles for the specific/pre-defined applications (websites), enabling the Log option which will allow you to check the IP addresses that are connecting to this site in the Gateway > Event log page.
  • JINHANG
    edited March 2017
    Can you provide a screenshot of NCC on what you are describing above? Thanks
  • Nebula_Bayardo
    For instance, if you want to check the devices that are accessing to Youtube you can create a application profile (Gateway > Configure > Firewall) using the pre-defined options for youtube, action "Forward", "Log" option and creating the outbound rule with source "any" or specifying the network address you want to monitor:
    Once you have create the profile and rule, you will be able to check the devices connecting to youtube in Gateway > Monitor> Event Log filtering by Application patrol category:
Nebula Tips & Tricks
