My Google nest mini is not connecting to my wifi
Sid4maniac
Hi team,
I am using ZYXEL VMG3925-B10C model modem. I am trying to connect my Google nest mini, but I am getting an error saying password mismatch but I'm sure that the password is correct. I tried to login to the admin of my router through web. When I clicked "connection status", I can see Google home mini there without an IP address also in static state. Any help would be appreciated. Also attaching a screen shot of the same for reference.
Any help would be appreciated0
Hi there,
According to the screenshot, not sure why the Google nest mini use static for IP source.
Two suggestions from me:
1. Reset the Google nest mini back to factory default to make sure it use DHCP for getting IP address.
2. check the VMG3925-B10C's LAN network setting to see if any static IP setting. If yes, remove it.
If still no luck, maybe try reset VMG3925-B10C back to factory default as well, then see if any improvement.
FYR0 -
@SEJ , I tried both options. Still not working
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
