Gs1920-hp48
Shrek1966
Shrek1966 Posts: 1 image  Freshman Member
edited June 2023 in Switch
Hi and thanks in advance . I have a problem with my gs1920hp48. the 192.168.1.1 wont open in edge or explorer. comes up with connection error.
i updated the firmware this it when it happened any help would be great
  • ZySec_Tech
    ZySec_Tech Posts: 5 image  Freshman Member
    Follow the steps mentioned by  @McKenzie33
    If you still face error, then check... your ISP network. Is the same IP clashing with your Zyxel device IP....? If yes, then Use ZON Utility to connect.
    ZySec_Tech | India
