vlan
Hello @baudetd,Welcome to Zyxel community.As @PeterUK suggested, please go to Configuration > Security Policy > Policy Control, and edit LAN2_Outgoing policy, change the "To:" option to from Any to WAN. This change will allow the LAN2 to communicate with the internet and not other internal interfaces.Thank you.
James0
Ok you mean lan2 (p4) then you need to make sure policy control from LAN2 is set to WAN not any.
James0 -
hi,
ok it's good !
can you tell me more about the différent pages (,is there a doc?
how could you also limit the flow on lan2 ?
version firmware is 4.35 , it's time to update!
Hello @baudetd,Do you mean BWM(Bandwidth Management)?Please go to Configuration > BWM, enable BWM and create a profile for LAN2 interface. Select lan2 as Incoming Interface and LAN2_subnet as Source, then customize the limitation such as bandwidth Shaping.
You may refer to our knowledge base articles or handbook page 788 for more.James0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
