Need product suggestion or advice
Hello all, need some help from some experienced Zyxel users. I've used a couple of the smaller Zyxel VPN firewalls, a decade ago, and really liked them. Need something for my "house," but I don't need anything residential, because I do a lot of experimenting for work, and a serious crap-ton of both OS image and video downloading (and uploading). Under normal circumstances, I'd use a plain router, but I have 2 boys getting to the age where they could quite possibly run across something that permanently warped their brain (nevermind malware, viruses, trojans, etc). Plus, I have gigabit broadband, that's *actually* gigabit, AND a backup satellite connection, so dual-WAN is a must. PLUS, if it's at all optional, I'd like a 10GbE connection, copper or via SFP, to my home studio (although I suspect any 10G connections are on the WAN side?)
So, based on that, what would you suggest...for dual-wan, gigabit throughput, intrusion protection, DPI, application/web filtering, virus protection...and possibly a 10G LAN connection? Just to get it out there, I fully realize this is overkill. I get it, but I am, if nothing else, a geek/nerd/tech-whore/etc, so there's no such thing as too much. My biggest thing is that I don't want to learn yet another CLI language, and I remember liking the Zyxel GUI, so there we are. Any thoughts or suggestions will be very appreciated.
This could be helpful:
http://linuxgizmos.com/10g-wifi-gateway-runs-openwrt-on-64-bit-freescale-qoriq/
or use open wrt on other suitable hardware i.e. a mini pc.
Hi @JasonO
Welcome to Zyxel Community
According your requirement, the SFP port and Content Filtering function is required for your scenario.
For this requirement,VPN series or ATP series should fulfill your requirement.
You can reference to specification table by following links:
VPN50/VPN100/VPN300:
https://www.zyxel.com/products_services/VPN-Firewall-ZyWALL-VPN50-100-300/comparison#specifications
ATP series(will launch in 1 month):
ftp://ftp.zyxel.com/ATP200/datasheet/ATP200_1.pdf
- 588 USG FLEX H Series
- 477 News and Release
