[NEBULA] VLAN limitation
jensskov
jensskov Posts: 12
Zyxel Certified Network Administrator - WLAN First Comment Seventh Anniversary
image  Freshman Member
edited April 2021 in Nebula
Hi
Are there any limitations on the number of VLANs that can be used on that NWS100-28?
  • Zyxel_Barney
    Zyxel_Barney Posts: 85
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    image  Zyxel Employee
    Hi @jensskov
    Nebula CC currently has some VLAN limitations to look out for:
      - Up to 1003 PVID + Allowed VLANs (per switch)
      - 1 Voice VLAN
      - Up to 10 Guest VLANs from RADIUS Policies
    Regards,
    Barney Gregorio
Nebula Tips & Tricks
