Random logouts/disconnections on a self-signed certificate connection
I'm having a strange problem with my connection to my USG60W from both WAN- and LAN-side logins to the Web interface. When working, suddenly after all between 2 to multiple minutes the connections resets and the browser is redirected to the Login-screen.
I only have one user on the USG60W, the admin-user and am the sole owner of the device-password.
The configuration has survived the last two firmware upgrades with no apparent problems at all and I am running the latest firmware version as of today.
But what is baffling me is the browser isn't just logged out of the login-session and sent to the login-screen, but I have to re-accept the certificate warning from Google Chrome and all other browsers, including mobile phones to which I draw the conclusion the connection has been reset and not only the login-session.
What can I do to fix this very annoying problem?
Sincerely, Ole
Sincerely, Ole
Hi @olenoerby
According this symptom, you can check your configuration by: Configuration > Object > User/Group > Edit “user”.
You can extend the setting as higher or 0 avoids session timeout.
If the symptom not improved, Could you provide the screenshot of certificate error that you mentioned.(The certificate information is required)
- 213 Nebula Ideas
- 566 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
