Where is WMM by SSID in Nebula
MShorty
MShorty Posts: 6 image  Freshman Member
edited November 2023 in Nebula
I had my access points setup and working until I switched to Nebula ... now I can no longer find the settings for how to prioritize traffic by SSID using WMM ... where is this setting in Nebula?
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    edited September 2022
    Hi @MShortly
    WMM is enable by default on Nebula, but we don’t allow to change the setting or specify the priority for SSID currently.
    We will propose the feature request and raise your post on the wireless idea.
    We suggest that you can set up different VLANs with different SSID and set up the QoS by VLAN ID on the switch.
    Or could you share your application and settings with QOS type SSID priority so that we can try to use other functions to help you?
    THANK
Nebula Tips & Tricks
