Nwa90ax guest and l2 isolation list
Hi Customer,
Thanks for consulting Nebula Support!
We’ll check this issue and update you if anything is in new progress.
Zyxel_Judy
Hi Customer,
We have found the White list doesn't appear after enabling Guest for SSID which looks like you mentioned already. We’ll fix the issue as soon as possible.
We'll inform you if there is any update there.
Zyxel_Judy
Hi there,
Thank you for your patience!
We’ve just solved this issue. Please check that again.
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
