SecuExtender IPSec VPN Client licenses
CP98
CP98 Posts: 5 image  Freshman Member
edited August 2022 in Service & License
After I activated the Zyxel VPN Client with a license key. Can I reuse the same key, for exemple, if I have to reinstall the Client on the same PC. What is one of the company PCs break, is the license key lost?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited September 2022
    Hi @CP98
    The license key is bundled with your PC when you activate it the first time.
    If you would like to use the license key on a different PC, please provide us the license key or contact with our local representative/support or put your requirement in the community so that we can help you to reset your license status :) .
  • Abbe
    Abbe Posts: 1 image  Freshman Member
    I need to reactivate secuextender ipsec vpn client
  • Zyxel_Stanley
    Hi @Abbe
    You may provide your license key of IPSec VPN Client to me by private message first, then I will further check if reactivate the key is acceptable. :)
Service & License Help Center
