Nwa90ax guest and l2 isolation list
hi, I enabled ssid with guest and then L2 isolation list, when I enable the latter no list appears, Nwa90ax supports guest, how can I do?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi Customer,
    Thanks for consulting Nebula Support!
    We’ll check this issue and update you if anything is in new progress.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi Customer,
    We have found the White list doesn't appear after enabling Guest for SSID which looks like you mentioned already. We’ll fix the issue as soon as possible.
    We'll inform you if there is any update there.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi there,
    Thank you for your patience!
    We’ve just solved this issue. Please check that again.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
