Connect clients on LAN 1 to server on LAN 2
lexeter
lexeter Posts: 3 image  Freshman Member
edited September 2022 in Security
Apologies if this is trivial but I could not find an answer via Google and I am not a trained network engineer.
Based on the network diagram below, how-if possible-should I configure the USG40? Thank you.
«1
    PeterUK Posts: 4,411 image  Guru Member
    So the two USG are local?
  • lexeter
    They are in two adjacent apartments, connected via Ethernet: One LAN port on the USG40 (Router 2) is connected to and assigned a static IP (192.168.147.98) by the USG60.
    Not 100% sure what you have done but there are many ways to do this one way without doing VLANs
    On the USG60 connect the WAN2 port to the USG40 OPT port.
    USG60 WAN2
    192.168.255.1
    255.255.255.252
    USG40 OPT
    192.168.255.2
    255.255.255.252
    USG60 routing rule
    incoming interface
    member LAN1
    destination 192.168.125.0/24
    next hop
    type gateway
    gateway 192.168.255.2
    SNAT none
    USG40 routing rule
    incoming interface
    member LAN2
    destination 192.168.147.0/24
    next hop
    type gateway
    gateway 192.168.255.1
    SNAT none
    USG60 policy control rule
    from LAN1
    to WAN
    you many add destination
    USG40 policy control rule
    from OPT
    to LAN2
    from LAN2
    to OPT
    from WAN
    to LAN1
    you many add destination and source
    mMontana said:
    I'd use only the USG60.
    But where's the fun in that ;)
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    The fun of USG40 as hotswap if USG60 take a nap.
  • lexeter
    Thank you very much for your answers! Apologies, because clearly my diagram is not sufficient to explain the setup, I have updated it below, hopefully it is clearer now. Unfortunately I cannot change the physical connection setup.
  • Zyxel_Cooldia
    Welcome to Zyxel community.    =)
    It seems to me that you can just add static route on USG60 to tell USG60 where to route subnet 192.168.125.X/24
    USG40:
    Lan 1 interface IP is 192.168.147.98/24, so that's direct route subnet for USG40. USG40 knows how to route to 192.168.147.90.
    USG60:
    USG60 don't know subnet 192.168.125.X/24, so we need to add static route on USG60.
    Static route 192.168.125.X/24 to 192.168.147.98.
    I don't think static route will work but have tested the way I said and works.
    So I tired setting up Cooldia way with static route and was wrong it does work but in order for it to work you need to set “Allow Asymmetrical Route” for policy control so would be good if this was done.
    Per Policy Control route type drop list for Symmetrical/Asymmetrical Route — Zyxel Community
    You may also need a routing rule on USG60
    incoming interface
    member LAN1
    next hop
    auto
    SNAT none
