Access Problem For Website Under Custom Ports
ahrasis
in Home Router
I am running a server behind Zyxel EX3300-T0 NAT (provided by Digi Malaysia).
How do I get the websites to work / accessible via the custom port 8080-8082.
Firewall is currently set to high (which is the highest) and I port forwarded several ports likes 80, 443 and custom ports 8080-8082.
I built several websites which work good on port 80 and 443 but those under custom port 8080-8082 did not work i.e. were not accessible. I tried lowering the firewall to the lowest but they still did not work.
If they use port 80 and 443 they do work though, even with the highest firewall setting.
Problem is solved. I cannot access from local IP / LAN browser only. Using external IP works. But it is weird since I can access / browse other websites under port 80 and 443 fine both from local IP / LAN browser and from external IP. Very strange but acceptable for now.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
