Connect clients on LAN 1 to server on LAN 2
So the two USG are local?0
They are in two adjacent apartments, connected via Ethernet: One LAN port on the USG40 (Router 2) is connected to and assigned a static IP (192.168.147.98) by the USG60.0
Not 100% sure what you have done but there are many ways to do this one way without doing VLANs
On the USG60 connect the WAN2 port to the USG40 OPT port.
USG60 WAN2
192.168.255.1
255.255.255.252
USG40 OPT
192.168.255.2
255.255.255.252
USG60 routing rule
incoming interface
member LAN1
destination 192.168.125.0/24
next hop
type gateway
gateway 192.168.255.2
SNAT none
USG40 routing rule
incoming interface
member LAN2
destination 192.168.147.0/24
next hop
type gateway
gateway 192.168.255.1
SNAT none
USG60 policy control rule
from LAN1
to WAN
you many add destination
USG40 policy control rule
from OPT
to LAN2
from LAN2
to OPT
from WAN
to LAN1
you many add destination and source
I'd use only the USG60.WAN1 and WAN2 on the internet.Lan1 192.168.147.0/24.Lan2 192.168.125.0/24.
5 -
The fun of USG40 as hotswap if USG60 take a nap.
Thank you very much for your answers! Apologies, because clearly my diagram is not sufficient to explain the setup, I have updated it below, hopefully it is clearer now. Unfortunately I cannot change the physical connection setup.
Hi @lexeter ,Welcome to Zyxel community.
It seems to me that you can just add static route on USG60 to tell USG60 where to route subnet 192.168.125.X/24
USG40:
Lan 1 interface IP is 192.168.147.98/24, so that's direct route subnet for USG40. USG40 knows how to route to 192.168.147.90.USG60:
USG60 don't know subnet 192.168.125.X/24, so we need to add static route on USG60.Static route 192.168.125.X/24 to 192.168.147.98.
I don't think static route will work but have tested the way I said and works.0
So I tired setting up Cooldia way with static route and was wrong it does work but in order for it to work you need to set “Allow Asymmetrical Route” for policy control so would be good if this was done.
Per Policy Control route type drop list for Symmetrical/Asymmetrical Route — Zyxel Community
You may also need a routing rule on USG60
incoming interface
member LAN1
next hop
auto
SNAT none
- 588 USG FLEX H Series
- 477 News and Release
