Configure RSTP
Hi Rahman,
Default spanning-tree mode is RSTP, so the way to configure just enable global spanning-tree and the port.
Configure a port as an edge port when it is directly attached to a computer. An edge port changes its initial STP port state from blocking state to forwarding state immediately without going through listening and learning states right after the port is configured as an edge port or when its link status changes.
Note: An edge port becomes a non-edge port as soon as it receives a BPDU.0
Hi Rahman,
Note: An edge port becomes a non-edge port as soon as it receives a BPDU.0 -
Thanks for answer. if we consider that 1-24ports is user ports, 25-28 uplinks I set it up like this0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
