NWA210AX Blinks amber for 1 second and green for 1 second alternatively
Hoffman988
Yesterday evening setup my new NWA210AX. This morning worked and the suddenly start to blink amber/green.
DESCRIPTION says:
"The Zyxel Device is booting up or is connecting with NCC."
I have tried:
Don't know that to do next?
DESCRIPTION says:
I have tried:
- Different cat cables
- Different Lan -ports on my switch
- Boot all devices
- Tried external power supply
- Reset button
Does the AP have a Gateway and a DNS server setup?
Hi @ Hoffman988You can refer to this article first.
[Nebula] What to do if the AP is offline?
Noted: Your AP has reset once, so you can try the default password 1234 or your Nebula password first. (The path is in the article).If you have a gateway in your network topology, please notice that don’t block the port 4335 and 6667
Please provide us the AP diag info if you can't still connect to Nebula. Let us check the AP information.Jay1 -
My configure is follow,
I have tried to connect the access point straight to router and fiber but same result.
Laptop works everywhere via Ethernet.0 -
Zyxel_Jay said:Hi @ Hoffman988You can refer to this article first.
ZON does not find the device.
@Hoffman988We’ve seen your topology. Because we can determine from the light signal blinking amber/green that there are two situations.First, you can check your POE Switch if it supports AT mode Power. If it doesn’t support, it affects your AP service.Second, do you have any VLAN settings? And what do you set up on the AP LAN IP page on Nebula in the below path?(Access point>Monitor>Access point>NWA210AX)If your IP setting is wrong, the AP gets the setting on Nebula and it can’t successfully online.Please help us check this setting or you can turn on Zyxel Support. ( You can refer to the article in the hyperlink). And PM us org/site name. We will check your AP setting on Nebula.ThankJay
I purchase a new router.
When i check router log there is no IP request from Zyxel. When i connect/power on Zyxel there is no log entry on router, nothing.
Then i discover that when i connect Zyxel to switch or fiber there is no link. Data led don´t even blink. Power on, power off, PoE or power supply nothing.
I believe the AC is dead or stuck some home.
Hi @ Hoffman988
As per the picture you provide, the NWA210AX doesn't send the data to any device.
The NWA210AX is abnornal, please help us RMA this AP.
Here is our RMA information. Thank for your help.Jay0
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
