Firewall USG110 with VPN connection via IKEv2 is not working both on Preshared-Key or Cerfiticate
ductiena12
I had read all the thread about IKEv2 on Zyxel forum but cannot successfully configure the firewall to do such thing. It's showed that there was a paring key but notthing more, client stuck at connecting forever. Does anyone know how to config IKEv2 on this firewall to work with an android phone ? I already configured IPSec IKEv1 and L2TP successful, but some device only has IKEv2 so I need IKEv2 as well.
Thanks for your attention.
FWI, it's on lasted fimware already, 4.72
Hi @ductiena12,
If you use the native ikev2 within Samsung devices , pleae kindly check that you have to add the second DNS Server.
Or please see the following link to find connectd ikev2 vpn by strongSwan.
https://community.zyxel.com/en/discussion/12522/remote-access-vpn-wizard-for-secuextender-ipsec-and-non-secuextender-ipsec-vpn-clients#latest
Thank you
Kevin0 -
Thank you for your reply. I already put 1.1.1.1 on the first DNS, and 8.8.8.8 on the second DNS.and the link you provided above, my firewall USG110 does not have option to export non secureextender VPN clients like in the picture. so no more further steps can be done.
here are my config onvpn gateway:Encryption : AES128/SHA256 -> DH14Interface = wan2_pppEnabled extend authentication -> AAA Method: default, -> user group: VPN UsersPolicy -> Host, 0.0.0.0Enable configuration payload: Range 192.168.50.1 -> 192.68.50.50first dns: 8.8.8.8second dns2: 1.1.1.1Encryption : AES128/SHA256 -> PFS: DH2and still cannot connect via IKev2. any suggestions? thanks
Hi @ductiena12,
Thanks your time today. Please find the PM. I have sent the SOP about ikev2 with mobile (psk,cert) to you.
And I can connect to your site by my iPhone.
I will wait your advance test. Thank you
Kevin
There is also problem to connect to my Samsung tab s7+ with iKev2.
gateway:
By using Pre Shared Key
Engcryption/Authentication: AES256/SHA256
Key group: DH2, DH14, DH21
Connection:
IP address pool: 192.168.99.1 - 99.30
Active protocal: ESP
Encapsulation: Tunnel
Encryption/Authentication: AES256/SHA256
PFS: DH16, DH20, DH21.
I can connect to the VPN100 IKEV2 by other Android devices but not the Samsung Tab S7+.
Would you help to tell if there is need to be set for connecting to S7+ ?
Which version of Android is running Samsung Tab S7+?Have you any declaration by Samsung that the Android version installed supports IkE v2?0
Hi @vpn100
Welcome to the Zyxel community, may we know what is your Android version of Samsung Tab S7+ ?
Thanks.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.2K Security
- 93 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 921 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 938 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
