USG 200 lan1 and lan2 communication
Fassori
Fassori Posts: 3
image  Freshman Member
Hello everyone,
on a USG 200 i've created 2 lan on 2 different ports,
P1: 192.168.2.0/24
P2: 10.0.0.0/24
Now, I need them to communicate, for a collaboration between the two offices.
I've added in security policies two active rules:
Lan1 --> Lan2 any - any - any - any - allow
Lan2 --> Lan1
any - any - any - any - allow.
But the two LANS seems not to communicate.
Can someone help me, please?
Thanks in advance.
Best Answers
    PeterUK Posts: 4,723
    image  Guru Member
    edited September 2022 Answer ✓
    Is in routing
    Use IPv4 Policy Route to Overwrite Direct Route
    unchecked?
    image  Guru Member
    Having it unchecked will solve the problem and allow Direct Route without making routing rules. So it this solved or not?
    image  Guru Member
    Is in routing
    unchecked?
  • Fassori
    Fassori Posts: 3
    thank you PeterUK for your answer, it was unchecked!
    image  Guru Member
  • Fassori
    Fassori Posts: 3
    I've done a NAT 1:1 on all the interested addresses (only five) as a workaround. This eve, after the office gone empty, I'll try the solution. Even if it was already unchecked.
