ATP100 WAN=PPPoE float ip, How to NAT inner Web site 192.168.1.37 HTTP service to External usage
Hi @cy358,
You need to configure DDNS first.
https://mysupport.zyxel.com/hc/en-us/articles/360007885880--ZLD-Where-to-configure-DDNS-settings-WebUI
Then, NAT port forwarding.
https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding
Connect your web server via DDNS name.0 -
Hi @cy358
Currently, the IP address field of NAT doesn't support the FQDN-based format, we already transferred this requirement to our future development evaluation, you could refer to this discussion ( https://community.zyxel.com/en/discussion/2583/virtual-server-fqdn-based ).
So, you might configure an IP address to User-Defined External IP field when you get a dynamic public IP, it’s should be an alternative method for you, as below:
Hi @cy358
Here is a workaround solution can provide to you for reference.
SETP1. Add a NAT rule, as below:
Incoming Interface set to “wan1”, the external IP set to “any”, and the internal IP set to “192.168.1.37”, assuming your external and internal mapping ports are 80 both. Besides, if the incoming interface is set to “wan” and the external IP is set to “any” the LAN PCs might not match this NAT behavior normally, so please uncheck “Enable NAT Loopback” option.
STEP2. Add a security to allow WAN to LAN traffics toward to the internal HTTP server.
So that the user who is from WAN can access the internal HTTP server.
STPE3. (Option) If you want to let the LAN user could access the HTTP server by the DDNS FQDN normally, you can add an Address record in the DNS settings, as below:
Then no matter the user in WAN or LAN, they all can access the HTTP server via the URL for example http://zyxelcso.ddns.net normally. If there is no this setting, the LAN hosts only can access the HTTP server via IP address for example http://192.168.1.37.
- 434 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 116 Nebula Status and Incidents
- 6K Security
- 393 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
