Nebula widget "AP Traffic" usage
Hi @GiuseppeR
The AP Traffic widget in Side-wide Dashboard shows the usage statistic of the top ten applications used that provided by Connect & Protect (CNP) service.
You can refer to the article for detail information of CNP features and license if you’re interested in the features.
https://community.zyxel.com/en/discussion/12468
If you’re not using the features of CNP the field will be blank, and you can unselect the item by clicking Customize > Widget on the top right of dashboard.
Thank you
Regards,
Bella
Hi @GiuseppeR
Thank you
Regards,
Bella
Thanks @Zyxel_BellaI see that CNP and CNP+ are available only for some selected models.No one is wifi 6E.Is there a way to have this function working also on other AP models (also on some basic Nebula AP like NWA50AX)?Is it hardware specific?I see also that there is a IP reputation filter included in the CNP base license: is it the same included in the UTM yearly license?Thanks in advance.
Hi @GiuseppeR
Because CNP provides advanced functions that are for enterprise models such as WAX630S, thus, SB model doesn’t support it, most of newer enterprise AP supports as the article mentioned.
We are not yet have plan to implement CNP service on 6E APs, we’ll publish release if any news in the future.
Yes, the IP reputation filter concept is the same with security product but CNP will be suitable for wireless environment statistical analysis.
Thank you
Regards,
Bella
- 441 Beta Program
- 293 Service & License
