VMG1312-T20B Help please
Nixon
Nixon Posts: 1
edited August 2023 in Home Router
VMG1312-T20B V5.30 (ABSB.0) C0 after firmware update V5.30 (ABSB.5) C0 password from back label does not match! What to do? Help please
  • SEJ
    SEJ Posts: 112 image  Ally Member
    Hi there
    Have you tried reset the device to factory default by pressing the Reset button over 5 seconds?
  • SEJ
    Hi there
  • Ruslan0709
    Ruslan0709 Posts: 4 image  Freshman Member
    reset from the overload button did not help.
    The router reboots, but the password from the back label does not work.
    Need *.rom loader
    сброс с кнопки перегрузка не помогло.
    роутер перегружается, но пароль с задней этикетки не подходит.
    Нужен загрузчик  *.rom
  • Ruslan0709
    SEJ said:
    Hi there
    Need *.rom loader
  • Hello! Did you solve you problem?
  • shurik
    shurik Posts: 2 image  Freshman Member
    остаётся выбросить на помойку и купить новый роутер другого производителя
