IPSec VPN Client to access LAN/VLANS behind USG210
tenniseric79
I would like to know how I can configure an USG210 (or USG60W for that matter) to allow a computer with IPSEC VPN Client to access different LANs and VLANS behind the firewall.
My setup is this:
Computer with VPN client connected to a LAN with ipadress 192.168.x.x
VPN-tunnel to USG210
Thjis works fine. Connected and verytning. This VLAN is 10.10.13.0/29. I can ping the USG2010 that has 10.10.13.2 as the IP on this VLAN (1013)
So, behind this I have serveral LANS and VLANS (my servers and other stuff lies on those).
How do I configure my USG to allow traffic to the other subnets....for example
VLAN1011 (192.168.11.0)
VLAN1080 (192.168.80.0)
VLAN110 (192.168.110.0)
I guess I should use policy routes and maybe zones, I just don't understand how...
I have doing some test and labb but I don't want to mess things up....
Any suggestion or examples....?
My setup is this:
What I do is make zones for the VLANs that way your individually making firewall rules for what VLAN can connect to a given VLAN but if you want it simple set all VLANs to LAN1 then make a firewall rule from LAN1 to LAN1 and they all connect.
You can enter to the Web-GUI path Configuration>VPN>IPsec>VPN Connection and edit IP range of the local policy such as following IP range 192.168.0.0./16.
Go to Configuration>Network>Routing>Policy Route and add a policy route.
Thanks.
Hi Jeff,
Can you reiterate that to a situation when one is using L2TP VPN? I reckon the policy route would be identical, but how does that translate to the local policy?0 -
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
