USG60W (V4.32) VPN Client to Site problem IKEv2 - tunnel established but no traffic
Hi everyone.
I'm trying to configure VPN connection (VPN Client to Site IKEv2 and Windows 10 VPN client) at my office, for remote users, but i have a problem. Tunnel is up, but there is no outbound traffic from the Zywall. Remote PC received IP address and is sending packets to Zywall, but no response. Any advice?
Policy Control:
Hi @Domel
As your description, there is no outbound traffic from ZyWALL.
The root cause could be on your local policy of this VPN connection(Phase 2).
Did you set local policy as 0.0.0.0~255.255.255.255 ? (You can reference to document page 7)
Yup. Range is 0.0.0.0-255.255.255.255.0
Hi @Domel
I will send you private message for check this issue more detail.0 -
Problem solved. By default, this option was not checked in the connection settings.
Zyxel_Stanley thanks for support and... patience0 -
Hi @Marcos
Please describe the issue in English on this forum.If you'd like to ask question in other language, please contact your local Zyxel technical support.Thanks for your understanding.If you want to see the option “Use default gateway on remote network”, you have to check on VPN Interface.
You can find this option by following steps:
1. Go to the “Network and Sharing Center”
2. Click on “Change Adapter Settings”
3. Enter into your VPN interface and Select “Networking” in Upper Bar
4. Click on “Properties” in Internet Protocol Version4(TCP/IPv4)
5. Click “Advanced” Button and then you can find the option “Use default gateway on remote network”.
Hello :)
I'm facing the same issue, client connected but no access to internal network.
I checked "Use default network..." but now i don't internet and still not access to internal network ...
Can someone help ?
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
