Force wireless user to go to certain website once
Hello all
A customer of ours has a NXC2500 WLAN Controller and NWA5123 access points. There are 2 SSID's configured which automatically connect to their own vlan. The users connect using SSID & Passwort, no captive portal used.
This customer would like the wireless-users in the guest-ssid to first, f.i. on connection to the wlan, go once to his external homepage with info on the hotel. There is no required login at any time, it is just to supply guest-info.
After that they are free to visit any page they want.
I am trying to find out if and how I could configure this. The Captive-portal does not seem to be the solution and I did not find another place to enter such info. Also the access points don't seem to provide such a possibility.
Does anyone have a suggestion or better yet, a solution?
Eric
Eric
Best Answers
Hello Joslyn
Thank you very much for the reply.
That sounds exactly like what our customer is looking for. So this firmware 5.40 will be for the NXC2500 oder do the access points need to have an update too?
Thanks again
Eric
Hi @Eric_
Provide the setting GUI for you.
If the customer does like not all the APs down at the same time, he can change it to manual before upgrading NXC firmware then upgrade the AP firmware one by one.(Choose the AP and click the "Upgrade". If the AP does not need to be upgraded firmware, the button will be grey out.)
Thanks.
Joslyn5
Hi @Eric_
Here is my understanding from your description.
The customer needs NXC pop out the hotel website after the station connects to the SSID. Then the station can surf the internet without any login information.
Please correct me if I am wrong.
If it is correct, this feature will be enhanced in firmware version 5.40 which will be released in the end of this year.
Thanks.
Joslyn
Hello Joslyn
Thanks again
Eric
Hi @Eric_
I saw the customer has NXC2500. He only needs to upgrade the firmware of NXC2500 because the AP firmware has been included in the NXC2500. It should upgrade the firmware automatically after upgrading NXC2500 firmware if the customer did not change the upgrade mode as manual.
Thanks.
Joslyn0 -
Hello Joslyn
The customer has wishes and needs but no knowledge of this system, that would be my job. This was my first WLAN Controller from Zyxel that I could install. I did not change the upgrade mode so it is good to know, that this will mean some downtime for all access points as well.
Greetings
Eric
Hi @Eric_
Thanks.
Joslyn5 -
Hello Joslyn
Thank you very much for the solution and the way to get this update installed in a controlled way. As soon as the update is there, we'll give it a testrun and then install it in the customers network.
Greetings
Eric
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
