Windows 11 and securextender frequent disconnects
IanH
IanH Posts: 4
Having major problems with having a stable connection on a Windows 11 pro laptop.  Have disabled wifi and using ethernet only.  Connection disconnecting after 2 minutes almost every time using a BT router, continuous ping which is sub 6ms and a 30+ broadband connection.
Have re-installed client, rebuilt laptop, disabled AV from the Zywall directory, turned off firewall as a test.  Also tried account from a seperate machine which is OK.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 795  Zyxel Employee
    First Anniversary 10 Comments Friend Collector First Answer
    Hi @IanH,
    Please kindly find the following FAQ to check if the symptom is the same.
    https://community.zyxel.com/en/discussion/14013/ssl-vpn-disconnect-due-to-invalid-packet-size#latest
    If the issue still , we can have remote session.
    Looking forward to your update.
    Thank you
  • IanH
    IanH Posts: 4
    edited October 2022
    Fantastic, I will give this a try and will report my findings.  Thank you for your assistance. 👍
  • IanH
    IanH Posts: 4
    The packet size was set to 1374, the issue is the firewall is on an earlier version of firmware
    V5.30(ABAR.0) / 2022-04-20 01:43:59
    Every time, I try and install the firmware it fails.  I have a workaround of setting up a ping but need to work out how to update.
  • Zyxel_Kevin
    Hi @IanH
    We have several SSLVPN issue on 5.30 .
    Did you have any error meassage when the upgrade failed?
    Kevin
  • IanH
    IanH Posts: 4
    Hi Kevin, no error, showing after the update.  Just the version is not changing from V5.30(ABAR.0) and then next log on, the update appears again.
  • Zyxel_Kevin
    Hi @IanH
    Could we have the remote session to check the firmware upgrade issue ?
    We can start at 15:00 (UTC+8). Please kindly provide the remote information and available time via PM.
    Thank you.
Security Highlight
