[NEBULA] What TCP / UDP Port Requirements are there for reliable connectivity?
CSmith_STC
Can someone please confirm what the TCP and/or UDP port requirements are for reliable connectivity between the NCC and any managed device?
With thanks
With thanks
I have found a reference to the connectivity requirements.
The client device initiates connectivity on TCP port 6667.2
The client device initiates connectivity on TCP port 6667.2 -
Hi @CSmith_STC,
I am glad you find the correct TCP port to initiate connectivity with Nebula CC.
You may also go to "HELP > Security policy information" to see the necessary TCP/UDP ports are used for Nebula device.
Hope it helps.
Jason0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
