How i can block VPN Hotspot
Hary1987
Hary1987 Posts: 13 image  Freshman Member
I have an issue, I configured to block some applications such as Youtube and Facebook on my Zywall, but some users installed the VPN software and they can access those websites normally. How can I block the VPN program?
    PeterUK Posts: 4,411 image  Guru Member
    edited October 2022
    Depending on the VPN it can be imposable to block even if you know the VPN being used.
    Depending on the model you have you can select “Tunneling and proxy services” for application to block.
    You could limit outgoing connections for DNS, HTTP and HTTPS
    In Content Filter block Anonymizers
  • Zyxel_Cooldia
    Hi @Hary1987,
    You can try to block by App Patrol Tunneling service. Select the Application name to create a app patrol profile and applying to security policy.
