Zyxel USGFLEX 200 problem with two PPPOE
Robert_air
Zyxel USGFLEX 200 problem with two PPPOE connections, I have a message like in the attachment.
What am I doing wrong that after 1 minute disconnects # 1 or # 20
Hi @Robert_air,
Welcome to Zyxel community.
Can you send me configuration file in PM for further checking.
Thanks.0 -
After turning on Spidernet_2 there are such problems as I described. I will add here that Spidernet has a constant ip and Spidernet_2 has a variable ip.
Hi @Robert_air,
Because both PPP profile Spidernet and Spidernet_2 are binding to the same physical interface OPT. It is unable to sends a broadcast PPPoE active discovery initiation packet (PADI) to discover with same MAC address.0 -
I understand, and is it possible to configure it correctly to make it work? Until now, I had a microtic router and several mac addresses can be assigned to each interface.
Hi @Robert_air,
Since FLEX200 is dual wan device, you can connect both wan interface for PPPoE connection.0 -
I ask if the sfp socket can be configured to run two pppoe ?
Hi @Robert_air,
It is also unable to run multiple PPPoE on SFP interface.0 -
It must be said that Mikrotic devices that cost less than $ 150 have this functionality. Do you plan to do a software update on your Flex devices to make it possible? If I knew that there are such limitations, I would never buy a Flex 200 and 500. I am waiting for the possibility of introducing a few pppoe and mac address on the sfp port.
Hi @Rober_air,
Can you share your scenario in practice ? Since our firewall is dual wan device, you can just dial pppoe on different external wan interface.0 -
The problem is that your device has 1x sfp and 2 x rj45 wan ports and I am not interested in rj45 ports because I have internet via sfp connection and here I can run up to 10 different pppoe but your router does not support it. Poor product for such money. I have another question, how can I transfer the configuration of the device from USG 110 to USG Flex 500, please send me a link because I know you have such a tutorial.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
