Hello,vmg8825-b50b is it possible to run as a wifi repeater
Imem_belhadj03
in Home Router
I have the vmg8825-b50b and i was Wondering if i Can turn it to a repeater wireless bridge extender wds what ever the correct name is i live in a rented appartement with free wifi but it's in the second floor signal is a bit low and slow.thanks
Hello @Imem_belhadj03
I have looked at the user guide for the VMG88250-B50B home router, and it cannot do what you ask.
Zyxel has some WiFi Extender repeater products, see https://www.zyxel.com/nl/nl/products/wifi-extender that should work for you, such as the WRE6605 AC1200 Dual Band WIFI Range Extender.
- which would give you both 5GHz WIFI and 2.4 GHz WIFI.
I myself use a similar product from TP-Link called the RE300, connected to a Zyxel Home Router.
I hope that this is helpful.
Kind regards,
Tony1 -
Thank you Tony i looked in the zyxel configuration settings and i couldn't find the option i was Wondering if the router is capable of it (hardware) and if there is a custom firmware that Can deliver this feature. Thank you for your response1
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
