IKEv2 VPN using Windows 10+ native client?
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
Has anyone had success using the built-in Windows VPN client and an IKEv2 VPN on Nebula?  I'm able to use the IPSec VPN without issue, but was hoping to "upgrade" to IKEv2.
  • Zyxel_Stanley
    Hi @TAPTech
    Nebula IKEv2 with remote access VPN tunnel only support for IPSec VPN Client.
    It doesn't support for Windows native client.
    Please consider to build IKEv2 VPN by IPSec VPN Client or change tunnel type as L2TP VPN on server side. :)
  • Zyxel_Stanley
    Hi @TAPTech
Nebula Tips & Tricks
