Can't upgrade firmware for NWA90AX
Because the latest version V6.29P0 is temporarily removed due to it has been verified it may cause repeated reboot in worst case scenario, the Nebula Firmware available status will display Upgrade available if device running non V6.29P0 firmware and can’t be upgraded.
We’ve checked your running version is stable, you can keep use without worries and please ignore if you received upgrade available message.
More information: https://community.zyxel.com/en/discussion/14786
Thank you
Jay
Hi @Angel3600
Please help us check your AP firmware version.
If you have upgraded to 6.27 p4, it is the lastest firmware version.
Don't worry about the warning "New firmware available"
We will fix the display bug as soon as possible.And we will inform you when we fix it.
If your version is before 6.27 p4, please PM us your org/site name. And activate Zyxel support located at HELP > Support request, so I could have the privilege to check the current status.
Jay0 -
I have the same problem, on 3 NWA50AX, all say update is available. all on version 6.25, I select them to upgrade to latest and a message comes up that they are on the latest version. Tried nebula and the mobile app, nothing is allowing them to upgrade.0
Thank you
Jay
Thank you Jay
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
