[NEBULA] What TCP / UDP Port Requirements are there for reliable connectivity?
CSmith_STC
CSmith_STC Posts: 13 image  Freshman Member
edited April 2021 in Nebula
Can someone please confirm what the TCP and/or UDP port requirements are for reliable connectivity between the NCC and any managed device?
With thanks
  • CSmith_STC
    I have found a reference to the connectivity requirements.
    The client device initiates connectivity on TCP port 6667.
  • CSmith_STC
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @CSmith_STC,
    I am glad you find the correct TCP port to initiate connectivity with Nebula CC. :)
    You may also go to "HELP > Security policy information" to see the necessary TCP/UDP ports are used for Nebula device.
    Hope it helps.
    Jason
Nebula Tips & Tricks
