GS-108B v3 Problems with connections
Just installed this one and some problems occur. First im using Virgin HUB 5 + Linksys Mesh. So for start .. i plug all in and my mesh works all OK. Then i try to connect my PC via cable and no internet. Unplugged all. Restarted HUB, then Started Switch, Then Linksys mesh. My PC now has internet but no internet on Linsys Mesh. And if i try to plug laptop it has no internet too. Not sure what's wrong but for first day and try I'm really disappointed. PC and Linksys mesh plugged in 7-8 (High priority) Hub in to 1
I think i sorted
Virgin HUB to Linksys Mesh and from mesh to Switch. Now working.
I think i sorted
Hi @Goncikas ,
It is glad to hear you have solved your problem.
If your topology was:
Virgin HUB – Switch – Linksys Mesh – PC
Please make sure that the switch connecting with the WAN port(Internet Port) of Linksys Mesh and PC connecting with the LAN port(Ethernet Ports) of Linksys Mesh.Since GS108Bv3 is an unmanaged switch, in addition to changing the traffic priority, switch will only forward traffic. If you connected your Linksys Mesh with switch at the LAN port of Linksys Mesh, it may makes Linksys Mesh can’t properly connect to internet because there is no connection at WAN port.
Kay
Kay
- 217 Nebula Ideas
- 577 USG FLEX H Series
- 297 Service & License
- 474 News and Release
