Connect PC (Client Software) to VM (with VLAN) with Ipsec VPN - ZyWALL USG100
Good evening to everyone,
I created a LAN on port 5 of the zyxel firewall, with 172.16.X.X network to which I connected
two VMs with VLAN = 10.
I have made a VPN between the Zyxel USG100 firewall and a Zyxel IPSec VPN client, but unfortunately I can only ping the IP of the firewall port 5 (172.16.X.1) but I can not ping the two VMs (172.16.X. 100 and 172.16.X.101).
Since I think the problem is related to the VM VLAN, can you tell me if there is a way to make the Client communicate with the two VMs?
Thanks in advance
Thanks in advance
Hi @EAQSUP
Does your VMs able communicate with USG100 successfully?
How about put a switch (for tag and untagged packets) between USG and VMs, and disable VLAN tag on your VMs?
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
