Old USG-1000 user - Licensing clarification for New Zyxel USG Devices
When you enter the brand new device first time, here is an Initial Setup Wizard to guide you on how to complete your device setting. Especially, there is a Register Device procedure and you could click the Register button on this screen to register your device at portal.myzyxel.com.
Then It will redirect to Myzyxel.com. then login with a Myzyxel account to proceed register procedure.
Once it is completed, you can see the message Your device is already registered. Now you can activate all security services. Click Activate All to activate UTM services.
Go back to Initial Setup Wizard, and click Refresh, we can see that Device Register status change to Registered.
Click Next to continue
Click Refresh to check Service License Status.
Click Next to continue.
As for the VAS (value-added services), I think it should be our Cloud Email Security service(MyZyxel> Cloud Services > Cloud Email Security).
Hi @mm_bretWhen you purchase a brand new USG Flex 200, you will have IPsec, L2TP, and SSL VPN in default status. Besides, you will also have a 30-day trial UTM license and you can deploy the USG Flex 200 in on-premise or Nebula mode, you can refer to the below table:
The more product information, please refer to this introduction link. You can refer to this link to see where can buy our product. Once the license runs out, you could go to our Marketplace to renew your license service. Thanks
.0 -
Pretty clear Jeff, thanks.One last thing. Does the device require registration to use?Thanks1
Hi @mm_bret
Once USG Flex200 is connected to the internet first time, its license service will be activated automatically. So, we suggest you register USG Flex 200 to Myzyxel(Please refer to this link.) and go to CONFIGURATION > Licensing > Registration > Service and click the "Service License Refresh" button to make sure your device has the latest security service signature for the better protection
. 0 -
Sounds like it won't work without registration?0
AFAIK the device will work. However, some VAS won't work if not registrated.
VAS (value added services)?
Jeff, you are a superstar for helping. This took some time. As well as you represent Zyxel, the registration process is a deal breaker for me..we've been using lots of USG 1000's for years withoutthe registration step. The devices are rock solid.I'm still not sure whether it work without registration...and I see this becoming a bigger part of theZyxel equipment line.Will keep an eye out for Zyxel's direction. Super bummed because most of the USG mfg's are going that way as well.Many, Many thanks for your patience,BretPS. I'll use a Freebsd device for the firewall, and then throw my hands up and accept registration perhaps someday0
Ordered a Flex 200.I just miss the Zyxel features too much.Plus some of my colocation service users would freak out if they didn't see their normalfirewall.Looking forward to discussions on the new firewall1
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
