GS1510-24 firmware
Hi @gck303,
Welcome to the Zyxel community!
V1.00(BVN.1) is the latest firmware of GS1510-24 since it has been end-of-life for a few years ago.
May I know why you are seeking for new firmware? Are you looking for new feature?
If you are looking for a new switch to replace your GS1510-24, I suggest GS1920-24v2 which has similar specifications to GS1510-24.
Hope it helps.Zyxel Melen0 -
Thank you. I am using this switch because I have it.
So long as it is the latest firmware, then I am sure it will work for my purposes. ;-)
Many thanks.0
- 588 USG FLEX H Series
- 477 News and Release
