API
ktaaps
ktaaps Posts: 1 image  Freshman Member
First Anniversary
Hi.
I have the need for a function in the API where you can turn off/on a POE port in a switch ? Have a big project where the customers needs to be able to turn on/off cameras through a very simple website/function.
The customers should NOT have access to the Nebula platform themselves as it might be many employees needing to be able to do this AND they must not be able to do anything else inside nebula.
Is that possible or can be added as a function to Nebula ?
It is very important for the project succes to be able to do this.
Regards
Zyxel Gold Partner
Nebula Tips & Tricks
