Not up to date, require upgrade to latest firmware although firmware status says good
IT_Engineering_1
in Nebula
The message still appers in the device overview although the newest firmware was installed on the devices.
Hi @IT_Engineering_1,
Welcome to the Zyxel community!
Which product are you asking for?
Could you provide the model name and the current firmware version?
And which firmware type did you choose? Is it "latest"?
Also, please provide your org name and enable Zyxel support for us to check.
Please access Help > Support Request > Zyxel support access to enable and save. Thanks.Zyxel Melen0 -
First many thanks for your quick response! The Organisation Name is "ITE" Zyxel Support Access is enabled. You can see the issue at Site "winter2". There are NWA50AX Accesspoints. The site is not in an production environment so feel free to perform restarts or anything else.
Zyxel Melen0
Hi @ IT_Engineering_1
Because the latest version V6.29P0 is temporarily removed due to it has been verified it may cause repeated reboot in worst case scenario, the Nebula Firmware available status will display Upgrade available if the device running non-V6.29P0 firmware and can’t be upgraded.
We’ve checked your running version is stable, you can keep using without worries, and please ignore if you received an upgrade available message.
More information: https://community.zyxel.com/en/discussion/14786
Thank you
Jay
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
