unintended reboots of the AP least at ten minutes times
Hi there,
To check the reboot reason, please help us collect the diagnostic of your WAC6103D-I & USG NXC5500.
The method to collect the diagnostic mentioned at the chapter 32’s part 32.2 Diagnostics NXC5500_V6.00.pdf (zyxel.com)
You can click to my account and send the file in private. We’ll check and contact you as soon as possible.
Zyxel_Judy
Hi there,
Zyxel_Judy
I send file to you
Thanks0 -
Hi there,
1/ After we checked the diagnostic file, there were no reboot reason and no abnormal reboot logs on the AP in this time.
The log information can show that AP reboot isn’t caused by hardware or software. It may be an external factor such as PoE, so please check cable/ power adapter.
_debug show file /etc/zyxel/ftp/tmp/reboot
debug hardware show-reboot-reason
Last Reset due to unknow!
2/ Regarding to the alert logs as AP disconnected.
The logs show disconnected time is quite same for APs, so we judge there is issue with your switch or power. We recommend you check your switch/ cable/ power adapter as well. Note that the AP’s status is updated every 120 seconds.
Moreover, we found that there are many APs managed by Controller dividing to 2 groups of CAPWAP method. Group 1: APs get 192.168.99.xx have CAPWAP as broadcast. Group 2: APs get 192.168.33.xx have CAPWAP as DHCP Option 138 with primary AC IP as 192.168.7.2.
In case the alert logs as AP disconnected for group 2, please check the intranet connection.
In addition, USG and NXC are the different APC Technology, so I’m so confused when you mentioned that your APs managed by USG NXC5500. Please make sense this point (I check the diagnostic file and know that your controller is NXC5500)
Zyxel_Judy
Thank you for your help. I will follow up with the questions you suggested
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
