USG40 WLAN port Offline
ivargas
ivargas Posts: 1 image  Freshman Member
Second Anniversary
Good morning, I have a USG40 unit and for two days I have had a problem with it, sporadically the WLAN interface goes offline, the only solution I have found is to reset it. Reviewing the log I find these reports but I don't know what I should do, can someone help me with the solution? Thank you. I copy part of the log
113
2022-10-31 11:12:17
info
Built-in Service
Enable daylight saving.
Built-in Service
114
2022-10-31 11:12:15
info
CAPWAP
WLAN Controller mode changed. Registration Type:Manual
115
2022-10-31 11:12:15
notice
WLAN Rogue AP Detection
rogue ap detection is enabled.
RAPD
116
2022-10-31 11:12:06
error
myZyXEL.com
Connection error has occurred.
117
2022-10-31 11:11:55
info
Interface
Interface opt_ppp has been changed.
CONFIG CHANGE
118
2022-10-31 11:11:55
info
Interface
Interface wan1_ppp has been changed.
CONFIG CHANGE
119
2022-10-31 11:11:54
info
Interface
Interface dmz has been changed.
CONFIG CHANGE
120
2022-10-31 11:11:54
info
Interface
Interface lan2 has been changed.
CONFIG CHANGE
121
2022-10-31 11:11:53
info
Interface
Interface lan1 has been changed.
CONFIG CHANGE
122
2022-10-31 11:11:51
info
Interface
Interface wan1 has been changed.
CONFIG CHANGE
123
2022-10-31 11:11:51
alert
Policy Route
Trunk SYSTEM_DEFAULT_WAN_TRUNK dead, related policy route rules will be disabled.
TRUNK DEAD
124
2022-10-31 11:11:51
info
Policy Route
Interface opt_ppp alive, related policy route rules will be re-enabled.
INTERFACE ALIVE
125
2022-10-31 11:11:51
info
Policy Route
Trunk SYSTEM_DEFAULT_WAN_TRUNK alive, related policy route rules will be re-enabled.
TRUNK ALIVE
126
2022-10-31 11:11:51
info
Policy Route
Interface wan1_ppp alive, related policy route rules will be re-enabled.
INTERFACE ALIVE
127
2022-10-31 11:11:51
alert
File Manager
WARNING: #configure terminal account pppoe OPT_PPPoE_ACCOUNT exit, Please type user.
128
2022-10-31 11:11:51
alert
File Manager
WARNING: #configure terminal account pppoe WAN1_PPPoE_ACCOUNT exit, Please type user.
129
2022-10-31 11:11:51
info
Policy Route
Interface dmz alive, related policy route rules will be re-enabled.
INTERFACE ALIVE
130
2022-10-31 11:11:51
info
Policy Route
INTERFACE ALIVE
131
2022-10-31 11:11:51
info
Policy Route
Interface lan2 alive, related policy route rules will be re-enabled.
INTERFACE ALIVE
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    I had similar issue with a USG60 few years ago.
    • Shutdown (via GUI) the device.
    • Wait for the communication of ended shutdown.
    • Unplug power adapter from the power socket/wall/whatever, keep it unplugged for 4 minutes at least.
    • Plug it back.
    Start monitoring again.
  • Zyxel_Cooldia
    Hi @ivargas,
    Welcome to Zyxel community.  :)
    Please help us to type CLI Router# show capwap ap all statistics when the issue happens again.
    We would like to check if it have TX power in wireless.
