Does the USG FLEX Series have Port Forwarding problems?
Hi @PaoloFracas
Thanks for your update. Or, you could adjust Egress Bandwidth to 1048576 Kbps and see if it's working for you when you are available.
And checking whether your wan and lan port speed are 1000M/Full both?
Thanks.0 -
I have tried both settings. The one with the line speed and the default one, but nothing change.
Hi @PaoloFracas
Could you collect the complete WAN and LAN interface packet files while you are backup files from the internet to the internal NAS server? BTW, please record the time point that file transmission is unstable. You can provide the packet files and unstable time points to us via private message. Thanks.0 -
I have the logs created on 04/08/2022 (dd/mm/yyyy) and sent to Zyxel but it is 2.09 GB
Zyxel Service is currently setting up a laboratory to perform tests.Today I would have to set up a Site to Site VPN to verify that the problem also occurs with this setup.I keep you updated.Thanks1
I can use WeTransfer but I need an email
@PaoloFracas
You can send it to my e-mail address and I will send a private message to you later.0 -
OKThanks1
- 220 Nebula Ideas
- 602 USG FLEX H Series
- 480 News and Release
